- Nov 29, 2014
- 24,995
Needing to pull the choke on to get clean running indicates a lean fuel situation in the engine.
This can be an air leak anywhere after the emulsion tube ( brass tube which sticks up in the carb.)
A low float level in the carb
Insufficient fuel supply to the carb.
If this is still happening the engine running lean will generate way too much heat for it to dissipate and that can cause it to be very difficult to restart but usually pulling the choke on full alleviates this situation.
Note it does not fix the problem , just works around it.
However I will wait for the spark test first.
The important thing is you only change 1 thing at a time or every one ends up really confused.
