OK, so I drained both fuel tanks. Replaced all the fuel line. But when I went to blow out the elbow that comes out of each fuel tank, there must be a check valve inside the tank. I noticed that there wasn't any air coming out of the top. Pressure was building up in the elbow and when I took the air nossle out of the elbow it blasted a mist of gas into the air. Certainly glad I had safely glasses on! It is still having the same problem. The only thing I have left to do is take the tanks off and remove the elbows from the tank. That scares me because I don't know how I am going to put the elbows back in. They are the opposite corner's of the cap. Any suggestions on that?Thank you very much. Weekend project! I will let you know how I make out.
Thanks for your help.
