- Nov 29, 2014
- Threads
- 64
- 24,718
Got 2 Dixons in the run
one has a low oil switch that will not allow the engine to crank
the other has a low oil switch that also trips a relay that shuts down the engine
I thought this mower had a tilt switch because it would stop when the customer was mowing his fence line which is on a compound slope
Then I would roll it to the flat to work on & it would fire right up
So after ripping it apart I realised it was the oil switch , by disconnecting it .
Trained the customer to mow the fence line in the opposite direction, problem solved.
Some of the older Honda horizontal shaft engine had a low oil shut down
And think the Kohler fitted to a Troy Built sub compact tractor had a low oil shut down but that customer died a while back .
