natenkiki2004
- Apr 22, 2011
- 13
- 177
Well I have it and so far there's a few issues but I don't feel ripped off or anything. Fair deal all around. I expected a winter project and that's what I got. Engine runs great, no smoke, no weird noises, didn't want to die or anything.
All the aesthetics are great too, no dents or major scratches, no cracks in the plastic. The seat and dash are really worn & sun damaged but that's not a big deal. Choke lever is gone but you can still choke by messing with the cable, I'll fix that though.
The biggest issue with it is in the steering. The pivot bar assembly, it's like a steel box that both the front wheels connect to, it's got a rip/crack in it but none of it is bent. I'm sure I can have the crack welded and re-enforced by a friend for low cost. It's also missing some of the pieces in this diagram:
http://www.partstree.com/parts/disp...=0&ilIF=G&ilRE=8&ilSH=0&ilEG=0&ilRO=0&ilSC=49
Number 24 is missing but buying 4 new ones might be $15, no big deal. Number 32 and 26 seem bent up but I should be able to bend them back. If not, a quick look shows that they're about $30.
I'll have to disassemble the front end but everything should come out from under the mower so it doesn't seem like too much work. I could replace a ton of stuff on this mower but to get it working again, it might be $40 plus the cost of a battery if I decide to buy one.
Pictures will come later.
