Mice in my engine or - I hate those mieces to pieces
Pick up a replacement carb online for $15-$20 (I replaced the carbs on my chainsaws for $15 and they worked great-cost same as a rebuld kit) and it will probably run better than it has for the last few years.
I save the net type bags/tubes that oranges and other fruits come in. Cut them into smaller pieces, put a few moth balls in them, cinch into a bag with old baler plastic twine.
I tie a small bag near/to the wiring in the dash, engine air cleaner housings and other places mice like to build nests and chew wiring. It only takes 2-3 bags per vehicle/tractor. By spring the mothballs have pretty much dissolved but meanwhile the mice leave the equipment and wiring alone, if your lucky.
I looked up B&S replacement carb 499158 and it is out off stock at B&S, but Jacks Small Engines has it for $162.47! Yipes! Overhaulkit $125.99. Double Yipes!!
Amazon and ebay have knockoffs for about $22 for the carb, but are they any good?
Ya git what you pay for.. $22. I'm thinking is a chinese knock-off
I've bought several of the Chinese knockoffs from Amazon and Ebay for chainsaws and weedeaters and go karts, they've all ran great. The two cycle carbs they even sent the tool to adjust the air screws. Just be careful to get the correct one, get the number off your carb and then compare the pictures that it's the same as yours.
Donb, if the engine started smoking and liquid coming out of the muffler, this is a symptom of a rich running condition. No need to replace the carb, just a need to give it a little TLC, a good cleaning and rebuilding. Don’t waste your money on a clone carb for a thirty year old engine. You won’t be happy. You don’t really need a full overhaul kit, just needle/seat and float bowl gasket. Disassemble the carb and find a local repair shop which has an ultrasound cleaner. I used to run them through the shop for free if they bought the parts from me,
