If we are going to get along together you need to do as asked and check the wiring diagrams are the same not just tell me the numbers are different.
AFAIK the wiring is the same as the looms on the 2 are identical right down to the index numbers.
A lot of mowers have identical looms.
So now to work.
1) download and print out the wiring diagram I posted.As we work through the electrics you can mark off what you found, it is a lot easier that way.
2) get some crimp on spade terminal and a few feet of wire which will be used to jump the plugs the switches plug into.
3) now describe exactly what happens when you turn the key on.
What you see , feel and what you hear.
