So, Thanks for all the replies and I went with an inexpensive Tach/Hour meter from Ebay. I didn't want to go super nuts so thought this would be OK for what I needed it for and the use I will be giving it. The only thing is you are supposed to wrap the pickup 5 times around the plug wire to get a reading. I seen on you tube ware a fellow added a clamp instead to the wire and seemed to work without all the wrapping and he did show a sample with two units one clamped and the other wrapped and they both showed the same so hoping this may work for me as well. I have the unit and put on the clamp but a bit to cold out to go to the shed and try it out but will later this week when it gets up to 40. Thanks, again for taking the time to reply.
