BBO
- Jun 9, 2013
- 0
- 126
That nylon connector plug looks exactly like the one that caused problems on my craftsman dyt 4000. I finally just cracked it open with pliers to look at the pins/sockets which were badly corroded. IMO the corrosion was dropping voltage (resistance) so I finally hard wired.
I replaced the complete plug, but it does require a a special crimping tool.
On the LX188 the plug carries the AC from the stator to the regulator on to the battery.
This may not be the problem he has with the mower not firing, but wiring connectors in general can sure cause problems.
Good engine ground issues are sometimes hard to locate.
I think I can check coils with an ohm meter, but some mechanics argue it's not reliable.
They say that when he coils get hot they loose spark even if they work after cooling off.
I do know that the plug wire cap can also be the problem, especially where it screws up onto the wire.
