LTX 1040 Carburetor
fayjim2
I need to rebuild or replace the carb on my LTX 1040 with the 19hp kohler engine. It has leaked from what appears to be the Solenoid. This year when I fueledup it must be leaking thru the needle. I removed the Air Filter and fuel ran out. So I need advice and parts # for a complete carb or a rebuild kit or solenoid and all gasket for the repair. I think its a 2011 machine The numbers on the carb LMK Walbro 3 154 01302005335 Mexico 3509 7561
Auto Doc's
Check out e-replacement parts or Jack's small engine online. You will need the numbers off of the engine label on the air shroud.
These engines were used on many different mowers,
Likely it is the SV590 LMK carb 20 853 89-S but as said need the engine model and spec numbers to be sure.
