LTX 1040 Carburetor
fayjim2
I need to rebuild or replace the carb on my LTX 1040 with the 19hp kohler engine. It has leaked from what appears to be the Solenoid. This year when I fueledup it must be leaking thru the needle. I removed the Air Filter and fuel ran out. So I need advice and parts # for a complete carb or a rebuild kit or solenoid and all gasket for the repair. I think its a 2011 machine The numbers on the carb LMK Walbro 3 154 01302005335 Mexico 3509 7561
Auto Doc's
Check out e-replacement parts or Jack's small engine online. You will need the numbers off of the engine label on the air shroud.
These engines were used on many different mowers,
Will need the actual model and specification number and in some cases the engine serial number from the engine tag
Likely it is the SV590 LMK carb 20 853 89-S but as said need the engine model and spec numbers to be sure.
fayjim2
Kohler 19 hp Model SV 590S Spec SV590-0220 SN. 4005615513 DOM 02/25/2010
That spec is coming up with it using a 20 853-35-S Carb.
Repair Kit 12 757 03-S
Solenoid Repair Kit 25 757 25-S. This includes the new heat shield for the solenoid.
fayjim2
Installed new aftermarket Carb. Won,t start unless spray fuel down the throat. Where does power to the solenoid come from and is there a fuse somewhere for this circuit. I believe the solenoid isn,t allowing fuel to flow inside the carb Help?
Savage3
Power comes direct from Battery via key switch Boss. You should hear the solenoid click when you turn the key to the on position.
If you can't hear click, check plug (connector at solenoid) for battery voltage with key switch in on position.
