trooper1954
- May 29, 2012
- 37
- 172
Thanks Bert....just wondering now if changing out the flywheel gear is really necessary? If the mower starts and runs fine once I manually turn the flywheel from the flat spot, will I do any harm running the mower like this for now?
Also, I'm now ready to look into the other issue I had....once the mower gets warmed up it loses power and will not climb the slightest incline. I'd like to change the oil in the transaxle and was wondering if anyone has a step by step for this? Do I have to remove the transaxle to achieve this, or can it be drained and re-filled while still on the mower? It's a Hydro-Gear 310-0500
Thanks for any and all help.
