Both top and bottom seals can be replaced with out disassembling the short block. Either by using the Lawn Boy seal remover tool or by VERY carefully using a small screw driver and prying them out. Put no pressure or very little on the lip of the seal bore. CAREFULLY side the screw driver between the crankshaft and the rubber lip and under the steel ledge of the seal. Pry upward. You can lay a thin piece of wood flat next to block to pry against to protect the edge of the bore lip. Do not scratch the crank surface.
