The point as that a four stroke runs in a bath of its own dirt and particulates and is far more likely to have bearing and bushing wear causing crankshaft play, and therefore seal damage.
A two cycle runs in fresh oil and is less likely to have bearing or bushing damage, and therefore less likely to have seal damage caused by crankshaft play. Since a two cycle does not have a crankcase full of oil and IS subject to rapid pulsations it is more likely to fail for other reasons, especially dry rot if it has sat for a few years.
Again...they are diffrent animals
