- Nov 29, 2014
- 64
- 24,705
Well bushfire season is here and the fire pumps are all coming in for "service" ( ie they won't start )
So the first one off the bat has the titled engine and no spark.
Tracked it down to the low oil switch
Now this is one I have never seen and simply screws into the extra oil fill hole
Downloaded the B & S IPL which shows a totally different switch # 790141 but that is a bolt in unit with an external module .
Any one familiar with this screw in switch or is it a local only part ?
It is a B & S branded pump fitted with a locally made Davey twin rotor pump .
