Loud banging noise when starting B&S
LostInMO
starter.jpgThis is my starter. Looks like metal. Not worn out, to me, anyway. I do not understand why it would start before I put the motor mount bolt in it but not after.
dougand3
Try starting while looking at how pinion interacts with ring / FW gear.
LostInMO
I watched. The gear goes up. Not exactly what to look for other than that.
dougand3
Getting info is like pulling teeth here. So, the pinion gear goes up...it meshes with the ring gear? it turns the FW and engine spins? Pinion just grunts and FW doesn't move?
If the starter spins the engine at a fast clip....the no run issue is elsewhere....fuel, compression, timing, etc.
Fish
I vote on loose engine mount bolts.
Just watch the engine with the hood up when you start it.
Fish
Lol, I just responded to a 6 year old question!!
To the new guy: Did you change the battery? If so, you may have it hooked up backwards.
LostInMO
Here is a video. Hopefully it helps to understand what is going on.
The battery is hooked up correctly.
Link to video:
Fish
Take off the top cover and look at things. I hear a noise like a loose coil or something rubbing.
Fish
We need to clarify terminology a bit. Starting vs. cranking, etc..
When you turn the key all of the way to the right, we should call "cranking".
So is your engine trouble cranking, and not starting? Or not cranking/spinning at all?
Start over from the start. When you tighten the bolt, will it crank?
dougand3
The flywheel looks to be spinning fine.....fuel/air delivery, compression, spark at the correct time....1 of those is faulty. Simple tests:
1. Pull spark plug. Re-insert in boot. Ground metal plug on cylinder fin. Turn key and look for spark.
2. Squirt gas into plug hole. Re-install plug and boot. Turn key and see if engine RUNS for 2-3 secs.
