Hi,
I have a 14.5HP Briggs engine and was able to get it running right, very smooth. As of today when
turning the key their is a loud banging noise and then it runs fine. So now every time
you start the engine their is a loud clanging noise and it goes way after the engine
runs for maybe a second or two. If it is the engine and not some issue with the mower deck,
what could cause this initial noise that then goes a way fairly quick?
Thanks,
Jim
Thanks,
Jim
