MasterBaiter77
- Oct 22, 2021
- 1
- 3
Got a LTX1040 with a drive pedal and break pedal (apparently there is a version that has a forward pedal and a reverse pedal?). The problem I'm having is as soon as I press the drive pedal (doesn't matter if FWD or REV on the gear shift) the tractor with go in that direction at full power but then speed drops completely. If I then release the drive pedal and press the pedal again, the tractor will move at full speed for a second and then nothing again. I can do this indefinitely, but my neck and back would hate me at the end of mowing my lawn. I can hear the engine go under load when I initially press the drive pedal, but after the first second it sounds like it's idle again. Engaging the blade works just fine and makes no difference to the drive train problem I'm experiencing.
