Looking to buy a zero turn or tight turn mower. Need some help
If you put a bagger on make sure you add some weights to the front or you will spend a lot of time looking at the sky.
You will like the easy deck coupling.
Get some 2 x 4 ' s twice as long as the deck is wide.
Slip them under the deck and drop the deck onto them then uncouple and slide it out on the wood like rails
Now I see how you work Logert. You post something, then realize what you did, delete it and post something else hoping no one saw it. Sorry I saw it and I guess you don’t want anyone see why I posted what I did. Your age and inexperience is showing.
I ended up buying the cub cadet ztr1 50 with the fabricated deck yesterday. I'm very meticulous with my snowmobiles, atvs and power equipment so I think it should last me wuote awhile. I'll use my air hose on it after every use and I wont use the deck wash system. I work on all my own toys so I'll pull the deck off a few times throughout the season and clean the deck etc. Like i said my lawn is pretty flat so I don't think it will get beat up too bad. I also used a 10% competitor coupon so I saved myself some money there. Now I just need to buy a striping kit and possibly a bagger. I have my atv that I'll use to pull my cart around the yard for debris pickup. I appreciate the help guys
Cutting the grass and leaving it on the lawn, is good fertilizer. Not to mention that layer of grass clippings helps to hold the moisture in & around the root system.
If it's the lines of dead grass that are unattractive, then you can raise the chute about half way, and it'll scatter instead of piling up in lines.
I want the bagger for the leaves during fall season. I probably wont bother with the bagger after reading quite a few bad reviews. I like that 2x4 idea though. As far as the deck wash, I could I imagine there would be issues with moisture getting trapped under grass on the deck. Therefore rusting prematurely.
Mulching the leaves has the same fertilizer effect.
On a personal note, I like the looks of leaves covering the yard. Not to mention, it's good ground cover for the grass and roots.
Hot bearings vs cold water. Seen this on many Jeep front spindlers over the years too. Cool that bearing down quickly and it pulls water through the seals due to contraction of air space in the bearing. You can do it, I don't.
