I don't know if it is allowed to place a link here. If not delete it. Just for help. https://nl.aliexpress.com/item/1005...3!sea!NL!758251723&curPageLogUid=hxIrD3b7V5Vn
This is the 590454!
			This is the 590454!
this is the closest i could find with the limited amount of info. https://www.ebay.com/itm/2851720297...cgfRNHFmRp3AEN+sxSCbF1HF0=|tkp:Bk9SR4T8upL-YQHi expert,
My Ignition coil is dead! yes, I tested with a ignition coil tester.
I search web for briggs and stratton "9945d" coil pack but found nothing with exact match!
Anyone know if there is a compatible coil that would work, thank you very much.
I replaced one just using the hp rating and brand of mower and it works great.I found this, hopefully enough: Murray 22", 5.75hp
Thanks.
Get one that’s close don’t have to be exact don’t turn it into rocket scienceHi expert,
				rubbed area on flywheel is from the brake, not the coil. Mowers with the blade stop brake all look like that.Does the ignition coil touch the flee wheel? On your photo it look like the coil already cleaned the side off the flee wheel. It may not touch the flee wheel, the gap between both has to be as wide as +/- 2 mm. As Thick as a card.
