looking for ignition coil for lawn mower
tracminhvu
Hi expert,
My Ignition coil is dead! yes, I tested with a ignition coil tester.
I search web for briggs and stratton "9945d" coil pack but found nothing with exact match!
Anyone know if there is a compatible coil that would work, thank you very much.
mechanic mark
Post model xxxxxx, type xxxx, trim xx, code xxxxxxxx from engine for correct coil, thanks Mark
If description does not state B&S OEM Part, it is cheap replica.
tracminhvu
I found this, hopefully enough: Murray 22", 5.75hp
Thanks.
Thanks.
What we need should be either stamped into the blower housing above the spark plug but could be under a decorative cover or stamped into the metal flap over the muffler depending on engine style
tracminhvu
found this: hopefully this it it, thanks.
Those are EPA numbers, which won’t help us. See IL’s post for engine numbers.
tracminhvu
Thank you all for all the help, I didn't know that is hard to find engine model for my mower, here are pics from all sides, and I can't find more information. At the very least, I think I will order 1 with the similar dimensions to make sure it fits, then cross my fingers.
Slomo, good to know, my mower has not been cleaned for 20+ years, lol.
The shroud in picture #5 has the engine numbers on that flap which will be over the muffler. I bet if you clean off that shroud you’ll find the numbers we are asking for. Also, that entire block needs a good cleaning.
