looking for ignition coil for lawn mower
tracminhvu
Sorry guys, I have to clean too much dirt to see this, is it good?
Priceless.......
Current superceded coil part number is 590454.
Your engine is location in the circled area but you need to clean it good to see it.
mechanic mark
A word to the wise, if part description identifies other than B&S OEM Part it is a cheap replica.
tracminhvu
thank you all very much for all the help, changed the new coil today, and get it run by 1st pull. :)
mcHarley
Hi, I am not always shure that it is the ignition coil! I see you already took it off. Well if you clean the coil, the side off the flee wheel and the connection where you fasten the ignition coil from rust, the ignition coil needs a good connection to the body of the engine. (Closed circuit) Like a battery won't work if you got a bad " - " connection!! Try this before buying a new one.
mcHarley
