looking for ignition coil for lawn mower
A word to the wise, if part description identifies other than B&S OEM Part it is a cheap replica.
thank you all very much for all the help, changed the new coil today, and get it run by 1st pull. :)
Hi, I am not always shure that it is the ignition coil! I see you already took it off. Well if you clean the coil, the side off the flee wheel and the connection where you fasten the ignition coil from rust, the ignition coil needs a good connection to the body of the engine. (Closed circuit) Like a battery won't work if you got a bad " - " connection!! Try this before buying a new one.
mcHarley
