D2hornets58
- Mar 4, 2012
- 25
- 288
It your machine and you have to know where the water come from, yes it could be condensation. I would have no idea how you use or store your ATV. White oil is from a lot of moisture. Now when you say white oil you are seeing through the small window that you check your oil level with? Do you get a lot of white thick goo on the oil fill plug? These are the only two spots that I can think of to see your oil unless you are taking things apart. Like I said this ATV is made to go in water and mud so this engine is sealed up and all vents and air intakes are high and come out above the gas tank.
Ya i am seeing it through the little window to check the oil level...And there is nothing on the oil fill plug.
