D2hornets58
- Mar 4, 2012
- 25
- 288
Ya i will have to order all that stuff soon and replace everything. I have replaced the rear bake shoes but not the front ones so I will do that when I get new cables.The front cables ten to break where they go to the front wheels. You will have to buy the complete cables and they can be pricey. Also if you replace the cables also install new front brake shoes.
Ok thanks for the help.Reynoldston has you on a better path than I do, follow his recommendations. He knows more about these units than I do.
Can't say I have ever seen a plow on a LT160. It is just 2WD and very light duty. Just how well does it work for you? Do you have tire chains or weight on the back? I have seen a lot of 4WD ATVs with plows.
Ya it doesnt seem like the ideal ATV to plow with but it does suprisingly well. It is 2wd. I dont use chains and dont put any weight on the back. I have no problem pushing snow as long as its not more then a couple inches. As long as i somewhat keep up with the storm then I have no problem. I get stuck every once in a while but not as much as you would think for a 2wd. I will try to get that bolt on the muffler out tomorrow and see if theres any water in there. Do you think I should run it for a while or just wait untill I need to use it and just use it then?
Thanks
