- Nov 29, 2014
- 65
- 24,772
First I am not JD service agent so I can post the relevant pages without contraviening my franchise agreement.
Second it is against the philosophy of public forums to send PM's with the information needed to fix the problem.
Otherwise you end up sending out 300 PM's
So here is the headlamp section of the manual.
My JD manuals mostly came from an old agency and in this case all of the full 2 page wiring diagrams were torn out.
Thus this is just the lights wiring bit
For those of you not used to JD wiring diagrams, the X numbers are plugs so X2 is plug as is X3. X9 is the plug with a yellow & a black wire near the hood hinge.
View attachment 325-Lights.pdf
And if I have not mentioned it before.
The JD manual is the best mower manual ever printed and all JD owners should buy one from JD as it will pay for itself 100 times over,
