I'm fixing up a JD 325. Among numerous other issues, it had no headlight switch. I purchased a switch and plugged it in. I have installed a new battery. Everything else is working properly, the PTO switch, fuel solenoid, etc. I have noticed the alternator light stays on most of the time. I cannot get the headlights to work. The bulbs and sockets both tested good. I put a voltmeter on the plug where you can disconnect to remove the hood and when I pull the headlight switch the meter reads about 12.70 vdc, so the switch appears to be operating properly. If I connect one or both headlight sockets to that plug I get nothing. The battery is reading about 13.40 vdc. I can connect the light socket directly to the battery and they work.
There are two wires, one yellow and one black. I'm assuming the yellow is hot and the black is ground so the light sockets themselves do not have to be grounded to the frame.
To say I struggle with electrical issues is an understatement. What am I missing?
