- Nov 29, 2014
- 65
- 24,995
Big engines run off heavy oils, small engines run off light fuels ( model aeroplanes run off either or metho )
They have injectors like fire hoses, each one individually adjusted in real time and a massive amount of momentum.
So provided the oil is clean & reasonably consistent they can handle it.
not too much different from old tractors than started on petrol then switched to kerosene ( parrafin to some ) once hot.
Ever wondered why airlines go bust as fuel prices fluctuate but shippings companies seem unaffected ?
They have jet engines that can start off burning Jet A1 then once at operating temperatures can burn reprocessed waste oil but the insurance companies will not cover the engine makers nor any airline burning waste oil.
I have a sneaking suspicion back in the 90's when domestic Russian planes were falling like rain from the skies the Soviets were trying duel fuel in their domestic jets but we will never know.
Reprocessed sump oil gets burned in a lot of locomotives as well, it is just a matter of atomising the oil so it can burn which in many cases requires significant pre heating.
