LETS SEE YOUR SNOWBLOWER!
detdrbuzzard
here are a few of mine
toro 826
toro 521 x3
toro powerlite E x2
wrong pic, haven't figured out how to delete it
toro ccr3000E
toro powershift xl824
I also have a ccr2450E, 3650E and a craftsman 536887251
tigercat
A 30 and 28" Ariens
A snow cab freshly mounted on the 30" machine
The working area of the snow cab
gfp55
Very nice units. Have they blown snow yet? They look brand new. I like the snow cab, dual lights and the drift cutters on the 30" one.
tigercat
The 30 inch machine I bought new 2 years ago and it runs well. I wanted a back up Ariens and found this 1 year old 28" deluxe machine a town over last week for $800. Low mileage but it needed carburetor work as it was stored with old gas in it. I serviced the machine and replaced the carb and it's running perfect now.
If you notice on both machines I painted over the original in dash head light and mounted an external light / lights that works very well. The 30" has 2 lights one on each side, but the little one I just added 1 light. What's wrong with the built in factory light? The light shines in my eyes and I can't see the ground around the machine as I blow snow in the early morning or late at night. It is also non adjustable. So I simply painted the light over so it looks clean, then replaced it with one that works. The light draws 35 watts each and the Briggs and Stratton engine puts out 9 amps of power, so the light stay nice and bright. I did switch the lights off when not needed.
I also added my version of "rolling skids" to both machines. I have to replace the original shoes before the season is done, as I have long side walks to clear plus a large drive way. These bearings "wheels" are sealed and roll without any resistance on my walks. They don't seem to wear plus they are sealed to keep water out.
For any one with the Ariens auto steer issue, or someone fighting with the machine wandering down your walks, these skids will keep your machine running straight as an arrow, until you decide on a direction change, not the machine....
I show how to build these on youtube, it's easy to do. Tools needed are a 1/2" drill, a hack saw and grinder to shape the old shoe and several washers. seen here.
https://www.youtube.com/watch?v=VG1giQ0heaY
gfp55
I did not notice the stock light that you painted over, you lights are way better then the stock light. Shine where you need it. I did notice the bearings on the skids. You did a good job to make them look factory stock. Good how-to video, easy to understand and you show how they work. Fine work. I hope you don't mind if I copy your idea for my machine? I will always give you the credit for the idea if someone asks. Thanks for sharing a very good idea.
tigercat
By all means, if you like my modifications, you may copy them. We are all on the same side here. :smile:
detdrbuzzard
had the two stage machines out the other day
gfp55
005 (3).jpgTractor is a 1986, blower is a 1985.
