Left steering arm stiff. Any help appreciated
Doug67301
My 1995 718K 52'' left steering arm gets hard to push forward at times. Half the time it moves normally. Reverse action, works normally. Changed the hydro reservoir oil and filter. No help! Tried adjusting the forward reverse linkage but no help. I returned adjustment back to original setting. Anyone else have this problem?[/B]
173abn
on my older 928d there is a grease zerk.not sure if yours has one but if it does might just need a little grease..russ
The arm has zero resistance, it just opens & closes a valve that is why there is a damper on there
Doug67301
I will check out these recommendations, thanks for your input.
