That is the operator present switch ... should be a place on the bottom of the seat or the system the seat attaches to the tractor... :smile:KennyV
I will keep searching for a place that it must attach. tks
BTW ...
Congrats on a DIY fix.... not only did you save some cash but you are now more familiar with your mower and will be more likely able to attack any other problem that may come up:thumbsup:...
If you roughed up the tank at the crack the epoxy should hold well, I prefer using a thermal repair, but I have read that there are some great epoxy products available ...
:smile:KennyV
wouldn't you want the gas tank repairs and surrounding cushioning material (if used) to be gas resistance material... idk just wondering :smile:
I have a L110 with a leaking gas tank. Is it possible for a homeowner to replace it or must it be taken to a service center?
