I would say you should be able to do the job yourself...if its the tank,consider getting a new tank if the price is not sky high.its possible i would think, that the tank on the tractor could act like a plastic gas can in the garage (swell up and suck in) therefore a 'repair' may not be the answer(flex).. while you have the tank out maybe put cushion strips on the tanks metal holding brackets. if its possible for you, it might be a good idea to change the fuel line,to eliminate problems down the road. maybe even get a new gas cap AND gasket (thats why my jd wouldn't stay running) gasket was crushed....:biggrin:just an idea here:thumbsup:
