- Nov 29, 2014
- 24,995
Like Star I am yet to find any JB weld product that is fit for anything other than a cheap bodge job to turn a profit or an emergency repair to get you home
However the warning was put out that once any sort of glue is used a proper weld is almost impossible .
It is Gasser tank so it is his decision .
I have done 5 JD petrol tanks with split seams , a couple of Murray tanks with wear holes from badly fitting bonnets , 15 JD hoods using the special JD filler rods, most were not pretty but they all held and about a dozen trimmer tanks that all worked except for two that were so brittle from sun exposure the tanks litterally fell apart but for those I managed to find a tank to almost fit then used some chain saw anti vibration rubber mounts as packing pieces.
