lcd screen said chg oil
2ball
So My led screen said CNG OIL. It did it for the whole hour right after I hit 550 hours.
There is no intelligence in that right?
It probably displays that every 50 hours?
It wasent because the engine go hot or somehow it knew my oil was old?
and there is no way to reset it like a car?
also 48 oz for my mower seems like a lot.
will there be an issue if I over fill it?
48 is the standard amount for most of the Briggs rider engines with oil filter. Some of the V twins are 64 ounces.
What mower and engine do you have?
I bought a used engine, ithe stamp on the valve cover is rusted over, but it is an I/C 17.5 HP B and S. It does not have an oil filter. I searched I/C 17.5 and the internet said 48 oz oil capacity.
That was the standard engine on the older John Deere D100.
Standard is 42 ounces without filter. At least for the OHV single cylinders.
My new Liberty is @ 18 hours, & the hour meter is flashing "Oil in 2.0 hours"..
I did the early 8 hour oil & filter change, & know this warning will stop when I hit 20+ hours, so no worries..
