Tomahawk1981
I've never tried to fix a lawnmower engine before. So I'm definitely a newbie
yes. that goes straight into the combustion chamber... about a tablespoon or slightly less ought to do it..So pull the air filter off, and pour gas into the hole behind it?
Yes. Yes on fuel in carb throat....but you've already done this with fuel in plug hole. It popped, so it's a fuel/air problem. This an auto choke-air vane/Thermostat. See that the choke plate in the carb (nearest the filter housing) is closed when cold. And it could be a dirty carb and fuel not getting to comb chamber.126T02-0125-B1
08082158
