Two-Stroke
- May 7, 2010
- 23
- 1,594
I'm new to the forum, and sorry have no pics. But we purchased a 'Silver Series' in 1996 for my Dad upon his retirement. He used it for quite a few years. After he passed away it sat in his garage for probably the last 5 years. I cleaned it up, cleaned out the carb, new mounting gaskets on the carb, new fuel and primer lines, new plug, cleaned the exhaust ports, lubed and tightened etc. It started on the first pull and I've been using it all summer now. It is LOUD, and it does have a vibration to it, but it runs like a champ. It's the first 2-cycle I've used (other than LB's we had when I was young). It smokes a little until it warms up then you really don't notice it. It has all kind of power. I believe it has a cast iron cylinder liner - which had no marks on it when I peaked into the cylinder. The only problem is the deck is rotting out. I may try to find a deck in better shape at the end of the season. Sad the 2-cycle is no longer made.
I'll bet sharpening and balancing the blade will cure the vibration problem. There have been threads about that in "General Mower..."
What is the model number on your mower?
