I did check again the spark on sparkplug remove and grounded : It seems very good and regular ;I remove the air filter, to look at the butterfly and inside carb. When i start the mower (high speed) it seems the engine is not able to reach the high rpm (vane at right ,view from rear) Then after about 2 mnures rpm rise and reach normal speed operation(vane full left ) . Then after, the engine will slow down ,very slow and lot of smoke ..
My question is a ignition coil can make this kind of engine run ? Thanks
