Kubota T1600H
I had the same problem with hard starting. After replacing many parts I discovered that the stranded ground wire bonding the frame and motor had broken. There was enough connection to enable it to start, but the resistance caused the need for more cranking amps. The problem progressively got worse until I discovered the broken wire at the ring terminal on the frame.
carving said:
What size socket do I need to remove the blades on RC44LT mower deck?
Could you not just try some till you find the one that fits
Sent from my iPhone using LMF
If it is intended for a trolling moter it is a deep cycle and won't last to long
