Kubota T1400 why the power loss ..?
bretonlion
Hi,
I have a Kubota T1400 Tractor Mower .. It runs Ok until you increase the revs or put a "load" on it ..
Then it looses power. Unplug the govenor or in France soleniod and it runs ok for a second .. but it does need the "govenor" ..
Everything else has been checked and as far as we can see is working Ok ..
Any comments welcomed ..
And where is the best place to get Kubota Spares from ..?
In France ths "soleniod" is 90 euro ..!!
Thanks
Rgds
Chris
:welcome: to LMF! I don't know the answer to your problem, but someone will! Good luck! :welcome:
KennyV
Hello Chris... WELCOME to LMF...
That should have a 13.5 hp Kawasaki engine so anyplace that has Kawasaki small engine parts should be able to supply parts....
The problem you describe sounds like it Could be fuel related... too much or too little, check for obstructed air filters and leaking intake gaskets first... :smile:KennyV
Briana
Welcome to LawnMowerForum!
I moved your thread to the Kubota Forum. :smile:
