goodolboydws
- Aug 21, 2010
- 1
- 12
It sounds as if you're headed down the road of replacing the controller box for no reason other than to stop the diesel pump from running momentarily. Depending on your inclination, mechanical and electrical ability, or financial wherewithal, there are several viable choices-some already posted.
1. put in a battery post-type mount power disconnect switch (quickest, simplest, and cheapest solution)
2. As someone else has already stated, you could simply wire in a battery power cut off switch. (dash mounted or easily accessible from there would be nice)
3. Keep checking eBay for a used one. Use a Want-It-Now posting if one isn't there in a week or 2.
4. Cut open the old box. If so, using a Dremel type tool often works with the least physical damage to the case. I've even opened up individually epoxy-potted relays this way TO CLEAN, BURNISH, OR BE SURE THAT THE INTERNAL CONTACTS ARE IN GOOD SHAPE and resealed them with epoxy afterwards.
Just for curiosity, before opening up a possible good part, You mentioned that this tractor is about 20 years old. Many times the electrical contacts in connectors as well as in relays can get crudded up to the point that whatever depends upon their proper functuioning will slowly get worse and worse over time. Did this problem suddenly start or was it intermittant for some time before being an all the time thing? If so, (and even if not) you might want to put aside the electrical meter and try closely examining and repeatedly plugging and unplugging every connector that comes from or that goes to that box, ESPECIALLY if one of those connectors is buried under layers of tape in the wiring harness. One of those may simply be oxidized or otherwise crudded up-you could get lucky. (if there are multiple pin connectors involved only one pin/circuit may be a problem)
I've come across this same type of age and crud (and sometimes road salt) related problem with many different circuit connectors on many different vehicles over the years. After cleaning out the connector as well as possible (sometimes a spray solvent helps) and carefully burnishing the metal contacts physically with an appropriately shaped metal tool or tiny wire brush I tend to put in a dab of dielectric grease-whether ther was some in there before or not, as it protects against future oxidation.
5. Bite the bullet and buy a new one.
P.S. I'm glad my old Ford 2000 doesn't have this problem-it uses a dash-mounted manual pump shut off cable.
