Nope. 55 hours on mine and never had anything like that happen. Though I've never taken the mowing deck off either.
Anyone having problem with belt being thrown, breaking?
To break a new OEM belt you most have a bad alignment problem. Bent brackets, bent pulleys, bad bearings, broken spindle housing Maybe remove the deck and check out everything very close, like cracks where the bracket fasten to the deck, or worn out bushings and bolts. Did you hit something?
Thanks KGW52
