Turbodriven
- Aug 18, 2023
- 84
Which cylinder is the problem? 180 is too high isn't it? 140 is a little low, but very acceptable for an engine with hours on it. Right??A ten percent differential between cylinders is what you are looking for as acceptable. I would check the valve clearance as a first step. Could be worn rings, partially blown head gasket, etc.
