Not really all that hard...You basically just enter the numbers. But I did cheat a little as I did use my barcode scanner for later lookups.
If you like to it just enter 021038203713 in your search bar. Or you could use https://www.barcodespider.com/
Now since I use a bar code scanner now for my business it is handy to scan barcodes. Right now I got only bar codes loaded but I can add more if I can which format they are in but even my distributors can't tell what those codes some OEM are using on their parts.
Heck if you are still learning you are still alive in my opinion.
