Kohler PH-XT675-2011
blaster 2023
Interesting, the yellow button, needle with Vitron tip and all the O-Rings are missing. I am waiting for the replacement carb.
Thank you.
blaster 2023
My Chinese Carb arrived, I installed it and it started on the first pull! I couldn't believe it. I tried mowing it seemed a little low on power
but I don't hear any strange sounds.
The mowing height was set very low, I raised it and it seemed to help.
Do I need to check the flywheel key? What RPM is the engine supposed to be set. Is 30W oil ok?
How do I check compression? The front wheel drive the cable is tied on with fishing line, any way to repair the end that goes in handle?
Thank You.
blaster 2023
I have it running, starts on the first pull, Replaced the Carb, carb gaskets, fule line (it was rotten), AND removed the fuel tank and washed it, bought fresh Gas and Sta-Bil.
When I emptied the gas tank into a glass bowel I had pieces of rubber hose, water and dirt.
What RPM is this motor set at?
Thank You.
