Kohler KT735-3012 starting problem.
rick10s
My lawn tractor was running fine 3 weeks ago when I parked it. Wouldn't start this morning. Checked plugs and filter both are good. After spraying starting fluid into carb. Started right up and continued to run. Shut it off after 5 minutes and tired restart. No luck. Went the spray route again and it ran. Any ideas?
Thanks
mechanic mark
See Troubleshooting KT735 & Fuel System pages 15-33.
Bertrrr
Sounds like a fuel pump or carb problem , I'd make sure the fuel pump is working first off , then look at the carb
hlw49
Check to make sure your choke is coming on.
check that the choke cable is closing the choke fully
rick10s
Thanks
Thanks for the reply.
What I don't understand is why it runs after starting with the starting spray. It literally runs until I shut it down but absolutely will not start without the spray. If I was having carb or fuel pump problems would it at the minimum run rough?
Because you need to apply choke for starting and restarts.
