Kohler K161 carburetor
Points is PN 47 150 03.
Your K161 appears to a coil located on the stator under the flywheel and would be PN 47 755 20-S. You try the aftermarket one on Amazon or Ebay as the OEM is around $200.
Lonestar
Yes, that's the parts number I'm showing on the points, with the condenser being 47 150 03-S. I just don't feel at this point considering the age of the engine and my knowledge, I can justify using original Kohler OEM parts. Who knows about other major issues such as valves, etc. I will say, the last time I ran the engine 20 years ago, it ran fine. I really goofed letting it set up.
