c5vettster
- Nov 9, 2014
- 7
- 48
No I haven't checked the key yet. I don't think it is timing though because of the way it originally quit on me. I could be wrong but I'm not sure how timing would get out of sync without some sort of catastrophic failure. Again, I could be wrong. Just a novice at this.
You may able to inspect it from the top to see if the slots on the shaft and flywheel are aligned. I suspect that your timing is fine given that change in timing often leads to violent backfire, etc.
Have you checked compression? It should put at least 60-70psi. I suspect that the valve clearance needs adjustment.
