I have a mid 1990s Craftsman lawn tractor with a Kohler CV15S engine. Background: 1) Had a small oil leak this spring. 2) Used tractor 2 times this year. First use while starting, it didn't start on first try and then sprayed fuel out of muffler. Then started and ran for 2 hours. Suspected fuel shut-off solenoid was bad. On second use after about 10 minutes, engine backfired and quiet. It would start but only ran at sub-idle speed regardless of throttle input.
Disassembled top half of engine, replaced carburator with new one. Replaced head gasket, Valve cover gasket, to fix oil leak and new carburator gaskets. Reassembled with new spark plug gaped to 0.040. Now engine does seem to fire at all. Checked fuse and interlock switches. Checked spark on engine block and check ignition module gap. Sprayed gas and and even starting fluids in carb. Still doesn't fire. I should also note that I can hear the engine intake pull air in when I turn engine. I am pretty sure the engine is getting fuel. Tested to carb and spark plug looks wet too. Noticed that valve lifters are non-adjustable type. However, it looks like the top valve, which I believe is the intake valve, is being depressed some even at its high point in the cycle. I suspect that the exhaust valve is also depressed some. I believe this is why it is not firing. Need help on what to do with this issue and what to do next.
