The engine is back together and ready to fire off and run.  Any thoughts on replacing the standard starter
with a High Torque Starter? Would a High Torque/Higher Amp Starter pull the engine through the high compression
spot? Nothing else seems to be working, and I hate to buy one of those expensive High Torque engine spinners just
to see it fail as well. Thanks.
