I don't have the model # handy, but this Kohler 19 Single, Twin Cam is on a Cub Cadet Riding Mower.
It will crank ok to a hard spot and will not go further without removing the flywheel
shroud and pull the flywheel through by hand. Once it's past the hard spot, you can
hit the starter and it will spin over and run. Is the compression release mechanism hard to
replace? I've seen some on E Bay for used cams and cam kits etc. The metal camshaft looks
to be one solid unit, cam and compression release combined. Will other single cylinder
cams interchange with the 19 single? I haven't pulled the top cover plate yet. Thanks!
