Thank you bertsmobile1,
First, I checked the torque on head bolts at 30 lb ft, all good.
Second, I pulled the head, found both valves leaking(water with air in intake and exhaust port, bubbles)
Third, I lapped and seated the valves, no more leak.
Fourth, I don't really understand the cycle/valve relationship on this motor. However, I inserted and marked the push rods at TDC, this was my observations where the push rods would push out of the cylinder/case, there by, would be pushing on the rocker arm, opening the specific input or exhaust valve. And, the push rod retreating back into the cylinder/case, which would be closing the specific input valve or exhaust valve and both of these in relation of position of the piston. Using the magnet on the flywheel is TDC at 12:00 and the magneto sets at 11:00. The motor runs clockwise.
TDC-where both valves could be adjusted, input and exhaust valves are closed. 12:00 is the piston at TDC and 6:00 the piston is BDC.
Cycle 1, 12:00-6:00, down stroke, from TDC,
Input valve starts to open at approx. 5:00 Exhaust valve closed
Cycle 2, upstroke
Input valve open Exhaust valve closed
Cycle 3, down stroke
Input valve closed Exhaust valve open from 12:00-closes in cycle 4 at 7:00
Cycle 4, upstroke
Input valve closed Exhaust valve open-closes at 7:00
Input valve opens briefly at 7:00 and closed at 10:00
My evaluation cycle 1, Ok, although input valve should have started opening from TDC.
cycle 2, If the input valve is open until cycle 3 where it closes at 12:00 and it was suppose to fire at 11:00, then no compression.
cycle 4, Where the input valve briefly opens and closes, valve spring compresses approx. 1/2 the distant s of a normally compressed open intake valve.
Maybe ACR(automatic compression release inside the case).
Actions,
1. Considering reusing bolts just purchased for current head gasket, also not sure if I should buy a new head gasket, what do you think?
2. Hoping after putting on the head tomorrow, I will have compression, but, not confident per above compression/valve observations.
3. Once I adjusted the valves, I will repeat you suggestion of rotating the push rods through the 4 cycles. Sorry, didn't mean to write a book, lol
4. Since I am a newbie, should I have opened this thread under kohler engines, should I ask administration to move it? Thanks
